3D Analyst Terrain to TIN resulting in z values that do not correspond with terrain
2471
08-23-2011 04:31 AM
StephanieSimpko
Trying to create a TIN from a LiDAR terrain dataset.  I am using ArcGIS 9.3.1 with 3D Analyst extension enabled for processing LiDAR .las files.  I created a terrain with reasonable elevations for my project area in Illinois.  Elevations in my terrain range from a low of 515.25 - 584.18, but the TIN that is created from it has an elevation range from 1690.449 - 1918!
I used "1" as the pyramid resolution z tolerance, which was also one of the pyramid z tolerances I used to create the terrain.  Used the default Maximum Number of Nodes of 5000000, and checked Clip to Extent.
I am able to create a reasonable raster from the terrain, but again, if I try to use the Raster to TIN tool, it results in the same elevation increase.
Has anyone come across this problem when you were still using ArcGIS 9.3.1?
Stephanie
Tags (1)
JeffreySwain
Since your differences from  are a factor of 3.28, I believe that you are suffering from the meters to feet conversion factor.  Are the units matching up?  Was there a change indicated between the processing?  I would check the units that the elevations are in.
StephanieSimpko
The distance units for the LiDAR data is in survey feet.  I just checked the terrain properties, and maybe that's the problem.  Here are the properties:
Data Type: File Geodatabase Terrain Dataset
Location:  \\CENTRAL\Shared\D3\Shared\Everyone\GIS\Grundy Co LiDAR\Geodatabase\Prologis.gdb
Feature Dataset: Prologis_Terrain
Terrain: Prologis_Terrain
Z Range: 515.250000, 584.179993
Pyramid type: Z Tolerance
Pyramid levels: 2
Total points: 11174864
Needs to be built: FALSE
Projected Coordinate System:  NAD_1983_StatePlane_Illinois_East_FIPS_1201_Feet
Projection:  Transverse_Mercator
False_Easting: 984250.00000000
False_Northing: 0.00000000
Central_Meridian: -88.33333333
Scale_Factor: 0.99997500
Latitude_Of_Origin: 36.66666667
Linear Unit: Foot_US (0.304801)
Geographic Coordinate System: GCS_North_American_1983
Datum: D_North_American_1983
Prime Meridian: 0
Angular Unit: Degree
Did I do something wrong when creating the terrain?  I don't remember any prompts saying that the units were being changed when creating the terrain, but it's been a while since I created it.  I'll create a new one to see if I can find where it is changing the units.
StephanieSimpko
Resolved the problem!  I needed to modify the properties of the coordinate system of the terrain dataset.  When I selected NAVD_1988 as the vertical datum, the Linear Units are in meters, so I had to click the Modify button from the Z Coordinate System tab in the dataset's Properties box, and change the Linear Unit Name from "Meters" to "Foot_US".  Once I did this, I tried the Terrain to TIN tool, and it produced a TIN that makes sense!
Thanks for the help!
Stephanie
