3d Analyst inactive
4465
7
08-02-2014 01:27 AM
EszterJákli
Hi all,
I would like to aks for some help. I imported a dwg file into ArcMap (with CAD to Geodatabase tool, then I also added the dwg with AddData)
There are contour lines in the drawing, and I would like to use 3d Analyst tool to create terrain model, analysis of slopes, aspects, etc. But when I enable the 3d Analyst tool, it is not active, and I cannot use any of its options.
In the ArcToolbox there are also 3d Analyst tools, can I do the same things though that?
I attach a screenshot.
Thanks a lot!!
eszter
Tags (1)
DanPatterson_Retired
Go to the Customize menu, select Extensions and toggle on the 3D analyst
EszterJákli
it is ON... (otherwise I couldn't see its toolbar)
Just checking...Yes you can do way more things in ArcToolbox's 3D toolset.  Also, the toolbar can be loaded even though the extension isn't...it will just be disabled...at least in version 10.2.2
EszterJákli
Ok, thank you. And do you have an idea how I could make it active so that I can use it?
The various options for the Toolbar require certain types of data.  Are your data in the proper format. or is it just a 2D drawing?
EszterJákli
there are 3d lines/polylines in the dwg file
maybe the Cad to Geodatabase would be useful getting the data into a useable form
