3D Analyst extension tutorial data
7191
7
05-25-2014 06:28 AM
JimWooten
Hello All;
I searched the 3D Analyst extension forum to find out if the issue of the missing 3D Analyst extension tutorial data was ever resolved.  I have 10.2 Basic and did a full install so the extensions tutorial data were installed except of course for 3D Analyst.  Can someone point me to the tutorial data or to a location where I can download the tutorial?  Thanks for your help.
Jim
Tags (1)
JimCousins
Try
https://customers.esri.com
login, and then download the tutorial data. It is 1.6gb, so I did not test it.
Regards,
Jim
ZachRogers
Jim,
I would like to use that 3d analyst tutorial data as well.  Was the link you provided specific to that user?  Can you provide it to me as well or expand on where in My ESRI I can find it?
Zach
JimCousins
Zach, this discussion was prior to ESRI's re-organization of their website.
I am afraid I do not know off-hand how to access this data now.
Regards,
Jim
MarkBockenhauer
Zach,
Some 3D data that you can use to learn with is located on ArcGIS online.
If you use this search URL:
http://www.arcgis.com/home/search.html?q=owner%3A3DGISTeam
A variety of templates will be returned.
The templates (zip downloads) contain a PDF tutorial and data.
Mark
ZachRogers
Mark,
That's strange.  The search you suggested does not return any results for on my computer.  However, I was able to find the ArcGIS 10.0 tutorial data here: ArcGIS 10.0 Tutorial Data DVD
MarkBockenhauer
Zach,
Good to hear you found what you were looking for.   As for ArcGIS online you have to make sure you check the "Show ArcGIS Desktop Content" check box, to see the results.
Mark
ZachRogers
Thanks for the help Mark.  That was the issue.
