Tiled Layer in WebScene
1786
09-06-2018 09:21 PM
MarcoPoetsch_ret
Hi, folks!
I have a question regarding a file format, which might be very easy to answer for some of you
I came across this nice WebScene here:
http://www.arcgis.com/home/item.html?id=ec8a197abf8b41f5b759c5c6e352f6c2
This WebScene includes different flood level layers
I would like to produce something very similar, and I'm wondering which format exactly I should use. The layers on the scene seem to be tiled layers.
What are the steps if I would like to make an equivalent layer on AGOL. (I have ArcGIS Pro 2.2.1)
Cheers,
Marco
Gert_van_Maren
Esri Alum
Hi Marco,
You can do this with the upcoming 3D Flood Impact solution.
Here is a link to beta 1 of the 3D Flood Impact solution. Please read the .doc for an introduction.
Let me know if you have any issues, comments, suggestions, other requirements.
Cheers Gert
MarcoPoetsch_ret
Hi Gert!
Your are great! Thank you!
I had a play with the solution you provided, and It looks really good and intuitive. Well done!
I have one more question: Is there an easy way to interpolate an exiting 2D flood extent from a polygon to multipatch feature?
The polygon is quite big and detailed.
Cheers,
Marco
