Need help draping image onto DEM
4600
11
02-23-2017 08:29 PM
MiguelSilva3
Hello;
I am new to ArcGIS and I need help with ArcScene. I have been trying to drape an aerial image which I exported from Google Earth onto a DEM I created; but I keep receiving an error:
"Base Surface
The layer and specified surface do not overlap in extent.
Verify they are for the same study area."
I have three files:
Contours
DEM and
Aerial photo
Both contours and DEM are a perfect match after selecting floating on a custom surface on Base Height in properties for each.
I will appreciate very much any help!!
Miguel
JayantaPoddar
MVP Alum
Try adding appropriate vertical offsets.
Vertical offsets for feature layers in ArcScene—Help | ArcGIS Desktop
Think Location
MiguelSilva3
Thanks..,do you have any experience with Aspect and Slope; in ArcScene the results are not quite intuitive:
