How to remove tiled appearance in ArcGIS Pro 3D Scenes
1444
04-06-2018 01:27 PM
AdamCares
How do I remove tiled appearance in 3D view in ArcGIS Pro? Every scene that I create, regardless of what layers are added, has dynamic gridlines over it that change as I pan and zoom, giving the map a tiled appearance at every scale. I would like to remove these if possible. The lines look like they are comprised of missing pixels, leaving lines of white holes in a gray map surface. See the attached photo for example.
DanPatterson_Retired
Display properties.... http://pro.arcgis.com/en/pro-app/help/mapping/properties/display-options.htm
rendering engine? cache? display properties? rendering property?
Anything there help?
