Create Vertical Lines between point datasets
945
11-18-2025 01:56 PM
LouisWorthington
I'm trying to create some strata land requirement plans and am needing to produce some vertical lines between 2 point datasets. Does anyone know of a tool that can do this?
BobBooth1
You can extrude points to some other elevation to display them as lines.
This process seems like it might work for you:
https://support.esri.com/en-us/knowledge-base/how-to-construct-3d-lines-for-underground-holes-in-arc...
