ArcGIS Pro clone data
1926
11-14-2018 03:31 AM
SatishMogarkar2
Hello, can some one answer me, If I have loading OR processing personal data (shape files or Geodatabase) on ArcGIS Pro software in any tools such Map, Scene etc. the software will automatically make data clone on his server. if it is true, Please let me know how avoid this?
thanks
 GeoNet Resource Hub
George_Thompson
Esri Notable Contributor
Are you asking if the software client (ArcGIS Pro, ArcMap, etc.) makes a copy of all data that you use for processing on the machine doing the processing?
If so, I would say no. It would use your input(s) data source and the output location. As I understand it the client does not keep any other data unless in a model and you have keep intermediate data enabled.
--- George T.
SatishMogarkar2
Thanks for quick reply,
As I understood that, Arc Pro, Arc Map not making any copy of all user data , which processed in ARC.
What does mean by unless in a model and you have keep intermediate data enabled? Please more elaborate
, thanks
George_Thompson
I would review the following documentation:
Create a model tool—ArcGIS Pro | ArcGIS Desktop
The in_memory workspace—ArcGIS Pro | ArcGIS Desktop
Considerations when using the in_memory workspace—Appendices | ArcGIS Desktop
The ArcGIS Products only make a "copy" for processing and then it is deleted.
What is your specific concern about the data that is being consumed/processed in ArcGIS?
--- George T.
SatishMogarkar2
Thanks for reply,
