3D layer isnt rendering in Scene View AGO
13684
26
01-21-2021 01:54 PM
msa4012
I was able to publish my ArcGIS Pro project to Web Scene, but the 3D Building footprint layer isnt draiing in the Scene Viewer. I do see the layer listed, and able to change the Symbology but cannot get the layer to draw on the map. I followed the steps mentioned here:
Authoring 3D Layers and Creating Web Scenes in ArcGIS Online (esri.com)
Tags (1)
RussRoberts
Esri Notable Contributor
Can you share the zipped gdb?
msa4012
Please find it attached here:
RussRoberts
I was able to publish from the hosted feature layer generated from the zipped gdb. https://www.arcgis.com/home/webscene/viewer.html?layers=ce5d13048fba41809f2b0c0a326e35e2
If you are still having issues I think you should contact support. but trial or developer setups do not support publishing multipatch hosted feature layers.
msa4012
Appreciate you spending your time on this. Will look into the license part. Thanks again!
msa4012
Not sure why, but I was able to publish the Multipatch layer after converting it into a 3DObject Scene layer Package.
RussRoberts
This wont publish a multipatch feature layer but will create a 3D Object scene layer from the SLPK.
msa4012
Yes, that makes sense. Even the ESRI support tech wasn't sure why I wasn't able to publish Multipatch directly. We have enterprise license so it shouldn't be an issue. At least now we know of a workaround if there's a need.
