3D layer isnt rendering in Scene View AGO
13650
26
01-21-2021 01:54 PM
msa4012
I was able to publish my ArcGIS Pro project to Web Scene, but the 3D Building footprint layer isnt draiing in the Scene Viewer. I do see the layer listed, and able to change the Symbology but cannot get the layer to draw on the map. I followed the steps mentioned here:
Authoring 3D Layers and Creating Web Scenes in ArcGIS Online (esri.com)
Tags (1)
msa4012
Here's the difference in Scene Viewer vs. Pro
RussRoberts
Esri Notable Contributor
Can you check the jobs pane in Pro to see if the job for the scene layer completed?
msa4012
This is what it shows
RussRoberts
Can you share the web scene and layers? You can create a group and invite russell_jsapi into it if you cant share publicly
msa4012
RussRoberts
Was a WFL with multipatch geometry type published? When I looked at the FL in the map it has this grouping. To have a 3D Object you will need a multipatch Feature Class in the scene in Pro and then that will generate a feature layer with multipatch geometry to go with the 3D Object scene layer
msa4012
This is what I am seeing:
https://arcg.is/910GS
The Building_Multi_3D is the layer created by using Layer 3D to Feature class tool. Thanks for your help.
RussRoberts
Can you share the Feature Layer associated with that Scene Layer.. it looks like its still private.
msa4012
I have changed the sharing on everything to public for this scene and all its associated Services.
