3D Cities: ETL/Interoperability Issue Exporting 3DCIM to CityGML
4183
07-15-2015 03:22 PM
VictorNgo
I am having issue with the ETL tools for interoperability from 3DCIM to CityGML. I am using the public CityGML 2.0 example dataset as a test, specifically the Building module.
1. I am successful in opening and viewing the CityGML dataset in a GML viewer using FME. The entire module is present.
     Dataset here.
     Log file here.
2. I am successful in translating the CityGML dataset to 3DCIM, and opening and viewing it in ArcGIS. All features are present.
     Log file here.
3. I translate the 3DCIM back into CityGML. However, when I open it in FME, I get an error message: "There is no geometry in this View."
     Dataset here.
     Log file (translating 3DCIM to CityGML) here.
     Log file (opening CityGML) here.
Can anyone advise? Why am I unable to load the CityGML file after translating it from 3DCIM? As a test, I tried using the example 3DCIM Portland dataset provided by Esri on Github and translating that to CityGML, and I get the same error.
MalvinaSalala
Hello Victor,
i also have the same problem. The only thing that i get as a result is just the footprint of the building.
Did you manage to find a solution?? What do you suggest?
