Is there a pulldata() syntax or some other way to perform calculations on a specific/previous record or records within a repeat? I am trying to make a series of calculations that compare the values between sequential records in a repeat.
For example, I have a repeat for collecting data for trees adjacent to a sample location. For report formatting purposes, these need to be recorded in descending diameter (largest tree to smallest). Within the repeat I have two user-entry fields ${treespecies} and ${treediameter}.
I want to also include a note to alert the user if they enter a value larger than a value in a previous repeat. I was hoping to use the Relevant function with a formula along the lines of:
(${treediamater, [previous value]} >= ${treediamater, [current value]}).
Another useful alert would be for assigning values for unusually large trees, for example a warning if a tree diameter is more than double the average diameter across all repeat entries.
