Populate a field within a repeat from a previous entry within same repeat?
4546
10-07-2019 08:00 AM
MattCobb
I'm working on a vehicle usage log for Survey123 that our field crews can track mileage for their vehicles.  Within a repeat group, I have fields of Starting Odometer and Ending Odometer.  Is it possible to auto-populate the Starting Odometer field based on the previous Ending Odometer record within the repeat?
DougBrowning
MVP Esteemed Contributor
I do this.
Create a field outside the repeat with a max on it and you will get the last value since you know it is the largest
max(${GapEnd})
Then in your repeat grab the max using once so that it does not change on you if they go backwards to view or edit.
once(${maxGapEnd})
DougBrowning
I do this.
max(${GapEnd})
once(${maxGapEnd})
MattCobb
Doug Browning‌ this is brilliant, worked perfectly.  Thanks a ton!
FRSadmin
Hello, I don`t know if you will see this so many years later.
I am pretty novice at coding and I am trying to do something similar but am missing steps in between.
I want to be able to have a pulldown list to select the vehicle, and then for each vehicle have each odometer information stored.
I guess my questions are
A) under the survey tab how do I link the data from my chosen vehicle to the starting Odometer
B) I am unsure if all of your code is direclty in the script portion? and how can I use the script under the survey tab...
FRSadmin
I responded to this just a few minutes ago but I am wondering if you could tell me? maybe show me how you were able to solve this.
I am not planning on having a repeat function, but rather I have a pulldown list of vehicles and then based on what vehicle you selected I want to be able to readin the Starting Odometer automatically.
Does this require a single script and then an individual excel spreadsheet for every vehicle?
For example if I have a Corolla selected, I need to have  a matching excel spreadsheet Corolla.xl that then has a start and end column? Or just a single column that then tracks different values?
A screenshot or anything you have would help wonders as  I also do not know Java...
