Hi. I used Microsoft Power Automate (MS Flow) a few months ago to set up a flow where if a survey was submitted a MS Teams message would be sent from the Flow bot to a user to let them know. It all worked fine.
I now have a new survey and would like to set it up again, but I can't get it to work. First of all my surveys won't list in the dropdown when setting up the link. I tried adding the surveyID in manually but then when trying to save the flow I get the following error:
The response from API 'survey123' operation 'GetWebhookPayloadSchema' with status code '200' does not contain a valid OpenAPI schema object.
I have followed the exact same process as the previous flows I set up. They still work so my accounts must still be 'linked'
Any ideas what I'm doing wrong?
Many thanks
Jon
