Hi all, I hope everyone is well
I'm trying to create an offline basemap in ArcGIS Online, to use in Survey123, which contains a satellite image and two reference layers (vectors). I followed Esri's link step by step (https://doc.arcgis.com/pt-br/arcgis-online/manage-data/take-maps-offline.htm#), but it didn't work as desired. The image appears as a basemap option, but the reference layers do not appear. I followed the following steps:
1- created a web map and inserted two vector layers (feature layer hosted);
2- I enabled both layers for offline use;
3- I enabled the offline mode of the web map;
4- in Manage Areas, I created a Map Area and save;
5- I opened Survey123, located the area created and downloaded it for offline use.
Does anyone have any suggestions on how to make the basemap offline display all layers? Is it possible to do this in Survey123? Am I missing something?
Thanks in advance!
