Can you have more than one user say 10 users on the same login filling out the same survey and submitting without issue on an enterprise in Survey123?
Hey Sherry Mattice,
From a technical side yes.
Ethically and licensing wise no.
Ben
If this answer was helpful please mark it as helpful. If this answer solved your question please mark it as the answer to help others who have the same question.
Sherry Mattice
Glad my response helped out. Feel free to @ me in any future questions you have about this sort of thing. If I helped out could you please go to my profile and mark up my skills (https://community.esri.com/people/bturrellesriaustralia-com-au-esridist) or give me a follow!
Hi Chelsea,
> ... "you can only login simultaneously 3 times with the same account". Has that changed since a year ago, or is Enterprise not limited?
Confirming this has not changed. A named user can only login simultaneously 3 times with the same account.
Hope this helps,
Can you simultaneously sign in on 10 devices though? Derek said in the thread above that "you can only login simultaneously 3 times with the same account". Has that changed since a year ago, or is Enterprise not limited?
As Derek Law states here, https://community.esri.com/thread/200812-arcgis-online-user-name-login-limit :
"This is not permitted and is a violation of the software terms of use. A named user account cannot be shared and is meant for a single, explicit user."
This is the policy across the ArcGIS platform, so both ArcGIS Online and Portal/Enterprise.
