From @JohannesLindner :
If multiple rules trigger on the same table, you have no control over the execution order, which can give unwanted results if a rule depends on a field that is calculated by another rule. Lessons Learned — Attribute Rules
Could attribute rules be enhanced so that we can control the execution order? That would allow us to split huge attribute rules into smaller more manageable rules.
@EstherSmith_Dev In regard to:
In database speak, are they similar to "after <event> for each row" trigger? e.g. if we want to check count of child features using FeatureSetByRelationshipName, it will include current feature being added as child feature?
Yes, the rule fires after the triggering event.
I agree @EstherSmith_Dev . The doc link you shared does have a section on evaluation order below the sections that describe the different rule types. The section links to the more extensive doc on evaluation order.
I'll chat with the team and see if there is a way to feature it more prominently.
On a side note, I found this interesting, just in general regarding how ArcGIS creates records in the DB, (not related to attribute rules).
Thanks @SSWoodward for clarifying the order of execution for Attribute Rules especially with Calculation first and then Constraint. It will be nice if the documentation mentions the order.
Is it safe to assume both immediate calculation and constraint rules fire "after event" i.e. after insert/update/delete event has occurred and database row now reflects the event action?
Vish
Thanks everyone for your ideas and comments!There are two ways that you are able to alter the execution order of the attribute rules on a class.
1. As mentioned, giving a new order number to a rule in the attribute rules view will reorder the rules without the need to delete and recreate.
2. If you are looking for a programmatic approach, the reorder attribute rules GP tool will also allow you to script changes to the execution order of existing calculation attribute rules. Immediate calculation and constraint rules are evaluated during edit operations for specific triggering events (insert, update, and delete) defined in the rule properties on the class being edited.Immediate calculation rules are evaluated first in their respective order followed by constraint rules.As constraint rules do not change the state of the data, they have no specified order.
Related:
Move attribute rules in Pro Dialog
You can always change the order of a rule by simply double clicking on the order number and changing it manually to the desired order.
@MikeMillerGISand @JohannesLindner:
Would there be any benefit in controlling attribute rule order of execution globally for that FC/table?
For example, the order ID would be a unique number between all calculation, constraint, and validation rules. The order ID would be honored, regardless of what kind of attribute rule is.
For example:
I don't have a lot of experience with attribute rules. So I don't know if that's sensible or not.
That screen shot was from 2.9. I believe it has always been there for calculation rules. It is not present for constraint.
@MikeMillerGIS
Thanks Mike. Just to clarify, does that functionality fully/currently exist in Pro? Or is it coming in a future version?
You can define the order of calculation attribute rules:
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
