When using Web AppBuilder to design Web Maps, you can use a Feature Service or a Map Service URL as the embedded map within the application, which is best practices and what are the pros and cons for each? Thank you
Hey Michael Thornton,
There is a really good overview of feature layer vs hosted feature layers here:
https://community.esri.com/thread/241755-difference-between-feature-service-and-hosted-feature-layer
Ben
Thanks Ben Turrell.
Michael Thornton,
I'd like to mention few quick notes on map service here as a lot of good info regarding feature service/layer found in the other thread:
As per pros and cons, in an enterprise environment:
But when it comes to choose between a map image layer and a feature layer (regardless of whether is it off a feature service or map service), I can think of few that you need keep in your mind:
