We are going to deploy an ArcGIS Enterprise v11.4 in high availability with a total of eight machines:-
1. Two portal machines
2. Two hosting server machines
3. Two datastores (relational + object) machines
4. Two webadaptor machines
I have doubts about deploying an object datastore in a high availability configuration, which consists of two machines. Which mode do I need to select, SingleInstance or cluster? As per the documentation, I am pretty clear that the mode can't be the SingleInstance for cluster mode; the documentation says that -
For SingleInstance mode only one machine is required and for cluster mode at least three machines are required but if we have only two machines for object datastore then which mode I need to select.
Or
It is not possible to configure an object datastore with two machines.
Any response will be highly appreciated!
Ayush
