This is more for informational purposes to hopefully help the community resolve this issue if they come across it (Knowledge Base)
Background:
We have an on-premise deployment of the Portal for ArcGIS product (ArcGIS for Server Extension). Currently running 10.2.1 but working on an upgrade to 10.2.2. Config-store/content directories are all local C Drive. Windows Server 2008 R2 64-bit Virtual Machine (VMWare) with 2 vCPU and 6GB Ram. The portal has a web-adaptor and is configured with Integrated Windows Authentication (IWA) using kerberos (and/or NTLM if needed). All communication over HTTPS using a TLS 1.0 or higher connection.
The portal has 1 federated ArcGIS Server (no web-adaptor) and designated as a hosting server. We have no publishers, the AGS hosting server is not used to actually host features/services, it is only there to enable users to upload zipped shapefiles (up to 1,000 features). We have a pretty large ArcGIS for Server deployment in our enterprise that our users publish to (outside the portal) and then manually register content with our internal portal if necessary.
Our Issue:
We had a lot of issues during the upgrade, but finally worked through them all except being able to add the AGS as a federated/hosted arcgis server. We were not able to do an upgrade in place (10.2.1 to 10.2.2). After about 90 minutes it would fail starting the windows NT service. A complete un-install of 10.2.1 and re-install of 10.2.2 pointing to an existing content directory worked. But the AGS federation was still an issues (for the past 2 weeks).
We watched network traffic, and when trying to federate the AGS it was calling a page like this:
we kept getting an HTTP Error code response 403 (forbidden) and an IIS log entry that looked something like:
#Software: Microsoft Internet Information Services 7.5
#Version: 1.0
#Date: <DATE> <TIME>
#Fields: date time s-ip cs-method cs-uri-stem cs-uri-query s-port cs-username c-ip cs(User-Agent) sc-status sc-substatus sc-win32-status time-taken
<DATE> <TIME> <Server-IP> POST /portal/sharing/proxy https://agsservername.domain:6443/arcgis/rest/info?f=json 443 <DOMAIN>\<USERNAME> <CLIENT-IP> Mozilla/4.0+(compatible;+MSIE+7.0;+Windows+NT+6.1;+WOW64;+Trident/5.0;+SLCC2;+.NET+CLR+2.0.50727;+.NET+CLR+3.5.30729;+.NET+CLR+3.0.30729;+Media+Center+PC+6.0;+.NET4.0C;+InfoPath.3) 403 0 0 306
We tried multiple methods of federating the portal (including manually doing it through the portaladmin rest interface). No matter what we did, we could not get past this 403 forbidden.
The Resolution:
After exhaustive research... (and about to open a ticket w/ Esri) we finally stumbled across the Configuring a reverse proxy server with your portal help article (which I do not remember when we originally installed our portal @ 10.2). Executing this configuration setting solved our issue!
Now we technically do not have a reverse proxy (other than the out of the box web-adaptor) in front of the portal, but it seems to have fixed our problem with the alias. We had also tested this in an environment without the alias and did not need to implement this configuration setting when we had no alias applied.
