In the old ArcMap, when using Select by Attributes you could build a query, click OK, and find the results and close the dialog window. If you then re-opened the dialog window for Select by Attributes, the last query was still there - very convenient when you need to run the query again.
In ArcGIS Pro, each time I reopen the Select by Attributes window, the old query is no longer there. I know there is a save button that allows me to save my query to disk but I find that less efficient and just clutters up a folder with a bunch of saved queries I may never use.
My simple idea is to keep the last query in the Select by Attributes dialog window in AGPro.
