I created a survey 123 using the web design vs connect. Didn't make changes to it though I did move it to a new folder in mu content someone said that may be an issue though it worked fine after that. Worked yesterday morning on one pc where I demoed it to a group to get them to start using. They requested a few changes went to edit the form and had not made any changes yet - in the design panel it requested I save and publish to save changes - did so and get save/published successfully, yet when I look it is asking me to publish again - and the survey works off/on sometime getting a 400 error and when I go to edit collaboration piece it wont allow to save without publishing changes when there are no and I have published many times. Finally get folks to use the survey then it wont work.
