Hi
I've just picked up on the new(ish) data download option in Dashboards. It's a great addition but it doesn't seem to work correctly for me when using a spatial filter.
I have a set of point features ('Units') in a map and I have a List element that has the 'Units' layer as its data source.
Each unit can be one of 5 types. I have a Category Selector that filters the list based on attribute 'Type'
When this attribute filter is applied to the list, the list displays the correct number of records and the download csv contains the correct number of records. So this works fine.
I also have a polygon layer in the map ('Centres'). Some 'Units' are in 'Centres' and some are not.
I have another Category Selector with 'Centres' as its source and it filters 'Units' using a spatial filter.
When a Centre (spatial) filter is applied, the List element displays the correct number of records (i.e. the Units within the chosen Centre). However, the downloaded List data contains extra 'Unit' records. These extra Units appear to be ones that are within the envelope of the filtering polygon, but not actually within its true extent.
I can't see any note in the guidance to suggest that download from a spatially filtered element is not supported.
Am I missing something or is this expected behaviour?
thanks, Neil
