My idea is to add a way to preview what the survey would look like before submitting. Instead of selecting the check mark to submit your survey, it would pop up a preview option that would allow you to preview what the survey will look like as a report. Having the users preview the survey in the exact format it is submitted in will help reduce errors and increase on efficiencies.
Example - Field user fills out a survey with lots of attachments and repeat records. It is taxing to have to tab through 25+ repeat records every time. So, the user clicks preview mode and can easily preview the survey as a report before submitting it. This will allow the user to preview the whole submission as a report and check for any errors in the process.
This would help my workflow of having to assist end users in deleting records and rows from the database because the user has no way to double check if the entries are correct.
