I know that 2.4 is coming, but I needed new functionality and some upgrades in numpy, scipy. I upgraded and have found no issues so far, but I was wondering if the alpha/beta team is using the new releases with it and whether anything on the list raises a flag that I should watch out for.
Here is the conda update and the module changes
(arcgispro-py3) C:\arc_pro\bin\Python\envs\arcgispro-py3>conda update numpy --no-pin
Fetching package metadata .............
Solving package specifications: .
Package plan for installation in environment C:\arc_pro\bin\Python\envs\arcgispro-py3:
The following packages will be UPDATED:
icc_rt: 2018.0.2-arcgispro_0 esri [arcgispro] --> 2019.0.0-h0cc432a_1
mkl: 2018.0.3-arcgispro_0 esri [arcgispro] --> 2019.1-144
mkl_fft: 1.0.6-py36hdbbee80_0 --> 1.0.10-py36h14836fe_0
mkl_random: 1.0.1-py36h77b88f5_1 --> 1.0.2-py36h343c172_0
numexpr: 2.6.8-py36h9ef55f4_0 --> 2.6.9-py36hdce8814_0
numpy: 1.15.4-py36ha559c80_0 --> 1.16.2-py36h19fb1c0_0
numpy-base: 1.15.4-py36h8128ebf_0 --> 1.16.2-py36hc3f5095_0
scipy: 1.1.0-py36h4f6bf74_1 --> 1.2.1-py36h29ff71c_0<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>UPDATE
Upgrade documentation, the 1.16 series is the last to support python 2.7
numpy/doc/release at master · numpy/numpy · GitHub General
numpy/1.16.0-notes.rst at master · numpy/numpy · GitHub specific to 1.16. further 'dot' modifiers are bug fixes largely
Scipy dumps 2.7 after this release as well. Plus lots of improvements
scipy/1.2.0-notes.rst at master · scipy/scipy · GitHub
