I am trying to create offline map areas in Field Map Designer. I have received zero issues with this map so far in the process of configuring this map for offline use, but when generating a map area, i get an error message stating "Error accessing item ITEM ID" At first, I couldn't search the ID number, but was able to find it when inserting it into the id= section of my URL. The item is the map area i was trying to generate.
Is there a reason the item cannot be accessed and giving me this error, and is there a way I can fix it so that the map area can finally finish packaging.
TYA
