Hello everyone,
I am currently having issues to understand the variables I get after executing the Emerging Hot Spot Analysis tool. They actually seem pretty different than what is indicated on the documentation : https://doc.esri.com/en/arcgis-pro/latest/tool-reference/space-time-pattern-mining/emerginghotspots.html?tabs=dialog
First, correct me if I am wrong, but from what I've understood from a previous post (https://community.esri.com/t5/arcgis-pro-questions/question-about-emerging-hot-spot-analysis-results/td-p/1190724), there are some variables present inside the summary table on the documentation page that are either included inside the 2D output feature (the "trend" variables mostly), or either included inside the 3D STC after using "Vizualise STC in 3D" with the "Emerging Hot Spot results" option (z-score, p-value and bin value of the Gi* itself).
However, the names of my tables fields are not the same than the ones of the documentation :
| OBJECTID |
| Time Step ID |
| Start Date |
| End Date |
| Time Step ID Exaggeration |
| Element |
| Location ID |
| VALUE_MEAN_ZEROS |
| Hot Spot Analysis z-score (VALUE_MEAN_ZEROS) |
| Hot Spot Analysis p-value (VALUE_MEAN_ZEROS) |
| Hot Spot Analysis bin (VALUE_MEAN_ZEROS) |
Attribute table of the 3D layer
| OBJECTID |
| Location ID |
| Category |
| Pattern Type VALUE_MEAN_ZEROS |
| Percent Significant Hot Spot |
| Percent Significant Cold Spot |
| Trend z-score VALUE_MEAN_ZEROS |
| Trend p-value VALUE_MEAN_ZEROS |
| Trend bin VALUE_MEAN_ZEROS |
| Sum VALUE_MEAN_ZEROS |
| Min VALUE_MEAN_ZEROS |
| Max VALUE_MEAN_ZEROS |
| Mean VALUE_MEAN_ZEROS |
| Standard Deviation VALUE_MEAN_ZEROS |
| Median VALUE_MEAN_ZEROS |
| Shape_Length |
| Shape_Area |
Attribute table of the 2D layer.
I suppose that on the 3D layer, "Hot Spot Analysis z-score/p-value/bin value (VALUE_MEAN_ZEROS)" is the equivalent of "EMERGING_{ANALYSIS_VARIABLE}_HS_ZSCORE" on the documentation.
My main problem is with the 2D table. There are two "Trend" variables on the documentation ("{ANALYSIS_VARIABLE}_TREND_ZSCORE" / "EMERGING_{ANALYSIS_VARIABLE}_TREND_ZSCORE"). From what I understand, the first one calculates Mann-Kendall on the location's values (for example NDVI in my case) while the second one calculates M-K on location's Gi* values. In my 2D table, there is only one "trend" value, which is "Trend z-score/p-value/bin (VALUE_MEAN_ZEROS)". Then, I would like to know to which one of the two variables mentioned on the documentation this variable refers to.
Does anyone in Esri Spatial Statistics Team (@LynneBuie, @LaurenGriffin) has an idea about what this "Trend z-score/p-value/bin (VALUE_MEAN_ZEROS)" refers to ? Or is there a problem with my software's version ? I precise that I have ArcGIS Pro latest version (3.7. while I'm writing this post).
Thank you very much for your eventual responses and sorry for my bad english.
