I am having issues trying to run an Export Data from a Feature Layer (hosted) on ArcGIS Online to a FGDB. This particular Feature Layer contains 2 related records tables and also an ATTACH table (with pictures). This however, is the same type of configuration I have setup for 5 other hosted feature layers that export to FGDB without a problem. When it fails, all that I see is a popup with a header of Error, and a message of failed. (attached)
The only way I can seem to back this particular Feature Layer up is when I do an Export to GeoPackage. (GeoPackage is the only other one that seems to maintain the related record and attach tables)
I would really like to be able to push this hosted feature layer to FGDB. Has anyone had any experience with this occurring to them? If so, what did you find to be the problem as to why you couldn't push to FGDB.
Matt
