Hi there,
Recently republished one of our map services in ArcGIS Pro that had been published via ArcMap. This Map Service has a tile cache.
Question 1: Why when Overwriting the established service is a new cache created with the name of the Service appended with the date and time? I would have liked the new service to reference the already existing cache, so now there's no way to switch the service back to
Question 2: I seem unable to find the right way to increase the Maximum Level of Detail setting in the Tiling settings for the service. I have a full cache generated with 13 levels of detail. However, whenever I've overwritten the service - the new service has now defaulted to only allowing 5 maximum levels of detail. The settings are greyed out in ArcGIS Server Manager, and changing them in the Service Properties via Catalog does not seem to have any affect, and the level of detail is still limited.
Is there a way that 1) when I republish a service I can make it use the already existing tile cache rather than generating a new cache with an appended date, and 2) that I can adjust the maximum level of detail for the service so that I can make sure it will use all 13 levels of detail to correspond with the large cache that has been used for the map service so far.
Thank you
