I am calibrating our site and testing and monitoring
shared service instance usage on the ArcGIS Server Site. I would like to be able to detect when the amount of requests to use our pool of shared instances exceeds the instances available-- particularly if there is a wait required for a free instance and when all instances are in use. I want to be able to track metrics on this wait time for requests to understand what % of the total time for a request it represents, know when it is a potential bottleneck, etc.
For dedicated services I don't have a great method for this either but I usually rely on gathering baselines for various request types and assuming slower responses that are concurrent with all instances for a service being in use as due to waiting for free arcsoc instances.
But with shared service instances it gets a bit more tricky. I understand that the " DynamicMappingHost" arcsoc processes handle shared service requests. But these are always running. So if I set our ArcGIS Server site to allow 8 instances, we will always have 8 running regardless of requests.
How can I determine when all of our shared service instances are in use and we are seeing response lag due to exhaustion of the pool of shared services and due to wait-time for a worker?
Some things I've considered:
- trying to look at connections in our database (all our shared services use SDE layers at moment) and determining # of connections, particularly for shared services. But I haven't determined how or if its possible to map a conn back to an arcsoc instance or whether it is initiated by something else, like a direct SDE or database conn.
- use logs and metrics from our proxy server and try to track ones to shared services to see load over time. This isn't ideal, as different types of requests trigger vastly different amounts of work for the server and determining what constitutes a bottleneck just from counting instances is not really possible.
I welcome thoughts and advice as well as corrections to any of the assumptions above-- like if a single dynamicMappingHost parallels requests rather than processing them one at a time, or if a single request will use multiple instances for faster response time.
Also I'm also interested for general ideas for dedicated services as well.
Sidenote: a particular beef: ArcGIS Server's built-in monitoring tools will detect service timeouts but they're pretty weak for calculating stats on timeouts or times on waiting for ArcGIS Server to start working on a request.
