Hello everyone
I am publishing a dataset to ArcGIS Server , the dataset and the feature classes have corresponding metadata in FGDC CSDGM standard - prepared using ArcMap
After publishing when I try to access the same metadata using server REST endpoint, the metadata seems to be in a different format ( may be ArcGIS metadata standard ,not sure though ).
My Question
1) Does Arc Server support exposing metadata in FGDC format?
2) Is there a way to publish only publish / update metadata (over a already published map service )
* ArcServer version 10.6.1 ( my environment is ArcGIS Enterprise 10.6.1 )
AGS is federated with Portal configured in HA
Thanks ,
Udai
