Variable_from_excel.py
2910
08-20-2014 04:44 AM
Tags (1)
Comments
XanderBakker
Esri Esteemed Contributor
Some pointers...
  • You don't need to use "gp = arcgisscripting.create()". Arcpy come with "AddMessage" too
  • You can use the "index" method on a list to get the index (will raise an error if the key field is not found)
  • Replace the dictionary.has_key(key) for key in dictionary. This adds to the readability
  • Will omit any field placed on the left of the ID field.
import arcpy
def Message(sMsg):
    print sMsg
    arcpy.AddMessage(sMsg)
# configuration
table = "C:\Users\deenr\Desktop\Data.xlsx\Sheet1$"
keyField = "ID"
fields = [fld.name for fld in arcpy.ListFields(table)]
fIdx = fields.index(keyField)
dictionary = {}
with arcpy.da.SearchCursor(table, ("*")) as cursor:
    for row in cursor:
        idx = 0
        for cell in row:
            if idx == fIdx:
                if not str(cell) in dictionary:
                    dictionary[str(cell)] = []
            else:
                if str(row[fIdx]) in dictionary:
                    dictionary[str(row[fIdx])].append(cell)
            idx += 1
# Print whole dictionary
Message(str(dictionary.items()))
for key in dictionary.keys():
    # Print Values
    Message(str(dictionary[key]))
Kind regards, Xander
RiyasDeen
Hi Xander,
Thanks for the pointers, should agree your code looks more elegant than mine.
Regards
Riyas Deen
Version history
Last update:
‎08-20-2014 04:44 AM
Updated by:
Contributors
