Use this layer package to display a point on each vertex in a line layer.
This is useful for visualizing the results of the Simplify By Straight Lines And Circular Arcs tool in ArcGIS Pro. Visualize the vertices and adjust the tool parameters to get optimal circular arcs (true parametric curves) from Segmented curves (approximate or densified curves) .
To run:
- Add the layer package to the map
- Open the symbology for your line layer
- Import the symbology from the layer that was added from the layer package.
You now see a dot on every vertex.
