List concurrent licenses script
2889
03-18-2020 11:44 AM
This script is a simple .bat script to list current licenses. This is a very low-tech alternative to the Where have all the licenses gone? application; it pops up a listing in a notepad window for review.
This script assumes that a current version of lmutil.exe is copied to the same folder as the .bat script. Alternatively you could edit the script to point to the lmutil.exe in the License Manager install.
:: lmstatus.bat
:: Report complete license manager status
:: Usage:  lmstatus {license server}
:: Curtis Price, [email protected], 09/08/2009 Original coding
:: cprice 03/07/2011 hide activations from output (find /v)
:: cprice 07/28/2016 set up HERE variable to run from anywhere
:: Edit the script to set LMHOST to your license server
@echo off
set LMHOST=%1
if "%1" == "" set LMHOST=arcgis.lic.xxx.edu
echo Checking licenses on %LMHOST% ...
set fn=%TEMP%\ESRILicenseUse.txt
echo %fn% > "%fn%"
echo. >> "%fn%"
set HERE=%~d0%~p0
"%HERE%\lmutil.exe" lmstat -a -c @%LMHOST% | find /v "ACTIVATION" >> %fn%
start /b notepad "%fn%"
Comments
AndresCastillo
Thank you Curtis!
This is beautiful and excellent!
It is because of your comment on ensuring that you have a current version of lmutil.exe that my team and I were able to get this to work.
See my comment on the other thread for the details:
https://community.esri.com/thread/7737-using-lmutil-lmstat-to-check-license-mgr-v10-status-on-a-remo...
also this free resource:
JTB flexreport light
AndresCastillo
I am providing an update to the attached WHATLG.zip file from that thread above:
Query the concurrent ArcGIS Desktop licenses from anywhere within network
https://community.esri.com/t5/arcmap-documents/query-the-concurrent-arcgis-desktop-licenses-from-any...
Version history
Last update:
‎04-05-2021 03:55 PM
Updated by:
Contributors
