Hi everyone
I use this .Net code to extract the photos and attributes of a collector dataset with location tracking on. The attributes of the feature dataset and photos can be download to your box. The web services of the features should be shared.
To use this, one will need to change the Url and hardcoded attributes.
The video is here Dropbox - AGOLdownloadData.mp4
One will have to configure the Url correctly. Below are assumed values
Srl# | Caption | Details |
1 | Assumed Url for feature service | http://somesampleserver.com/FeatureservicePath/ArcGIS/rest/services/LabOfflineGdbT3/FeatureServer/0/ query?where=1%3D1&objectIds=&time=&geometry=&geometryType=esriGeometryEnvelope&inSR=&spatialRel=esriSpatialRelIntersects&resultType=none& distance=0.0&units=esriSRUnit_Meter&returnGeodetic=false&outFields=*&returnGeometry=true&multipatchOption=xyFootprint&maxAllowableOffset=&geometryPrecision=& outSR=&returnIdsOnly=false&returnCountOnly=false&returnExtentOnly=false&returnDistinctValues=false&orderByFields=&groupByFieldsForStatistics=&outStatistics=& resultOffset=&resultRecordCount=&returnZ=false&returnM=false&quantizationParameters=&sqlFormat=none&f=pjson&token= |
2 | Assumed Url for download attachment | http://somesampleserver.com/FeatureservicePath/ArcGIS/rest/services/LabOfflineGdbT3/FeatureServer/0/ queryAttachments?objectIds={0}&f=pjson&token= |
3 | Assumed Url for location service url | http://somesampleserver.com/FeatureservicePath/ArcGIS/rest/services/LabOfflineGdbT3/FeatureServer/0/ query?where=1%3D1&objectIds=&time=&geometry=&geometryType=esriGeometryEnvelope&inSR=&spatialRel=esriSpatialRelIntersects&resultType=none& distance=0.0&units=esriSRUnit_Meter&returnGeodetic=false&outFields=&returnGeometry=true&multipatchOption=xyFootprint&maxAllowableOffset=& geometryPrecision=&outSR=&returnIdsOnly=false&returnCountOnly=false&returnExtentOnly=false&returnDistinctValues=false&orderByFields=& groupByFieldsForStatistics=&outStatistics=&resultOffset=&resultRecordCount=&returnZ=false&returnM=false&quantizationParameters=& sqlFormat=none&f=pjson&token= |
How to use the executable
- Fill the main tab
- Fill the locations tab
Screenshot index | Value | Description |
(1) | http://somesampleserver.com/FeatureservicePath/ArcGIS/rest/services/LabOfflineGdbT3/FeatureServer/0/ query?where=1%3D1&objectIds=&time=&geometry=&geometryType=esriGeometryEnvelope &inSR=&spatialRel=esriSpatialRelIntersects&resultType=none&distance=0.0&units=esriSRUnit_Meter& returnGeodetic=false&outFields=&returnGeometry=true&multipatchOption=xyFootprint& maxAllowableOffset=&geometryPrecision=&outSR=&returnIdsOnly=false&returnCountOnly=false& returnExtentOnly=false&returnDistinctValues=false&orderByFields=&groupByFieldsForStatistics=& outStatistics=&resultOffset=&resultRecordCount=& returnZ=false&returnM=false&quantizationParameters=&sqlFormat=none&f=pjson&token= | if your collector dataset has location analytics on. Combination of a. Json web service b. Search all attribute of webserice which can be hardcoded |
- Processing (Check video of processing)
- Click the “extract” button.
- Wait for the values to get populated
- Check the “logs” tab to check success of processing.
- Click the download button, select a folder. A CSV and folder for photos are created.
- Next to do
- Automatically iterate the attributes of dataset
- Validate the webservice urls entered
