I am the GIS Coordinator for the Public Works Department of my organization, assisting workflows for our field crews. I was faced with the task of creating a “Sewer Lateral Launch” field app that can easily track where, how, why, when, etc.
The below documentation shows the steps I took to complete the success of this task, as well as explaining some additional workflows that were be achieved in the process:
• Creating general template for Public Works Sewer Lateral Launch field application within Survey123 (using Geotrace) and integrated with FieldMaps
• Plot a Geotrace line using distance (manual entry), coordinates (precalculated), and bearings (precalculated)
• Calculated necessary trailing zeroes to verify precision of Latitude/Longitude coordinates
I attached a PDF with my methodology (apologies if it is long-winded), as well as Survey123 Connect excel document for reference. I am not an advanced Survey123 Connect user, so I am well aware that the hidden-dummy fields in the form could probably be consolidated, however thru a full day of testing: it works. I also am providing all my sources that I referenced to help design the form (infinite amount of thank-yous to all contributors on this site):
Primary Sources used:
* https://stackoverflow.com/questions/2187657/calculate-second-point-knowing-the-starting-point-and-distance
* https://www.fcc.gov/media/radio/find-terminal-coordinates
* https://community.esri.com/t5/arcgis-survey123-blog/what-s-new-in-arcgis-survey123-february-2021/ba-p/1030586
* https://community.esri.com/t5/arcgis-survey123-questions/survey123-how-to-maintain-trailing-zeros-in/td-p/865486
* https://community.esri.com/t5/arcgis-survey123-questions/survey123-leading-zeros-for-integer/td-p/806983
Other Sources Used:
* https://gis.stackexchange.com/questions/463758/survey123-submit-survey-as-geopoint-geotrace-or-geoshape
* https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/calculate-geometry-attributes.htm
* https://community.esri.com/t5/arcgis-pro-ideas/calculate-the-bearing-of-a-line/idi-p/973006
* https://pro.arcgis.com/en/pro-app/latest/help/editing/create-point-features-along-a-line.htm
* https://doc.arcgis.com/en/survey123/desktop/create-surveys/xlsformformulas.htm#ESRI_SECTION1_BB97985CAFB740EE8AEF99EFD6E238E3
* https://doc.arcgis.com/en/survey123/desktop/create-surveys/geotracegeoshape.htm
* https://www.youtube.com/watch?v=IVz4f36xwUs
* https://community.esri.com/t5/arcgis-survey123-questions/create-a-line-feature-from-two-geopoint-collection/m-p/1279330#M48625
* https://community.esri.com/t5/arcgis-survey123-questions/points-to-line-in-survey123-web-form/td-p/1280388
* https://community.esri.com/t5/arcgis-survey123-blog/survey123-tricks-of-the-trade-pulldata-quot-layer/ba-p/1224415
* https://community.esri.com/t5/arcgis-survey123-blog/survey123-tricks-of-the-trade-xlsform-functions/ba-p/893567
* https://community.esri.com/t5/arcgis-survey123-blog/use-existing-data-in-your-survey-the-pulldata/ba-p/896889
* https://community.esri.com/t5/arcgis-survey123-blog/work-with-csv-data-in-arcgis-survey123/ba-p/1157642
Hope this helps somebody.
@DougBrowning
@IsmaelChivite
@abureaux
@Katie_Clark
@ZacharySutherby
@TylerGraham2
@JamesTedrick
