Hi, I would like to include a map in a survey 123 form that we can use to gather data on the popularity of roads near a community. Is it possible to include a map of roads and allow folks to do something like select their top 3 most used road segments? I see there may be an option to do this using an .svg but was hoping that this could be done with a map document so I could avoid the process of converting to an .svg and then editing the .svg to include a bunch of mapped areas around each road, but I will go that way if necessary.
If .svg is the only option, hoping for some advice for my scenario if you have similar experience. For example, can someone point me to a tutorial workflow that might include illustrator and or photoshop for how to export a map with polylines that I can convert to an .svg that has the proper paths for each line feature to utilize as an image map for survey 123?
b
