How can I add a text that appears in the bottom-right corner of the map service as those for esri services (sources and “powered by Esri” logo)? This is better illustrated with the screenshot below
Thank you and Best Regards,
The sources text comes from what ever you have in the copyright text of your map service,see:
Attribution | API Reference | ArcGIS API for JavaScript
As for the logo see this thread:
Add source and logo to the map service
Many Thanks Anthony for your valuable input.
I got your point about the sources text.
Regarding the logo, it seems that you mentioned the link to this thread instead of the link to the logos thread.
Sorry Not sure what happened there, try this link:
Replace ESRI logo with custom logo?
Thank you again Anthony,
Is there another way to insert the logo without dealing with code (actually I am not a developer)? I mean when publishing the service from ArcGIS Server
No, it's a feature in the relevant api (in this case JavaScript), the only option you have is to change the code
Thanks a lot Antony for the helpful contribution!
