PROBLEM: Using Survey123 Connect, we have built inspection surveys that are used to inspect plantation areas and generate actions where required. Currently, each type of inspection can cover multiple categories in the one survey (lots of types - e.g. plantation health, roading maintenance, infrastructure). For each cateogry that is inspected, a "Follow-up Action" repeat records recommended actions that should be completed to rectify issues identified. Each of these repeats though is a separate table. This means that it's difficult for Managers to collate the data or review it without further data manipulation/merging of tables.
IDEA: We are currently limited to only using a repeat once. Allow for a single or multiple repeats to be used multiple times in a single survey.
USE CASE: Different parts of a survey can trigger the need to create a repeat record which currently results in separate repeat tables being used across the survey, A single repeat that can be reused will streamline data capture, analysis and reporting.
