Hello, hoping someone could help me out because I am beyond stuck!
I've created a gdb in ArcGIS Pro with GlobalID > guid relationships and published to AGOL. Lets say my database consists of Parent1 with layer id 1, Parent2 id 2, child1, child2, child3. The ids are from the service item details page.
I am trying to create two separate surveys for the same existing hosted feature layer. Survey 1 has Parent1 in the form_id colum of the xls form and repeats called child1, child2, child3. Survey 2 has Parent2 in the form_id and the same repeats.
I need this structure because some status fields are edited in the parent layers, and it allows technicians to create entries in each child layer without having to go back to Field Maps and open a new survey for each one.
When I try to publish Survey 1, I get Parent layer ID 2 not found for table child3. The survey publishes when I remove the repeat called child3. When I try to publish survey 2, I get Parent layer ID 1 not found for table child1. When I remove child1, I get Parent layer ID 1 not found for table child2.
I found this thread
https://community.esri.com/t5/arcgis-survey123-questions/publish-error/td-p/1009217
and saw that someone was able to fix this by copying the child layer, but this is not an option because I need all the child data in one layer, regardless of which parent it is related to.
Is there anything I can do to make this work?
