ArcGIS Pro Questions
452
143.8M
18.2K
NOTE: ArcGIS Pro ideas require a single label. See the descriptions to choose the label that best aligns with your idea submission.
Open | Move the New Folder, New FGDB, etc options out of their 'New Item' menu in the various Save & Open dialog windows.The... by RTPL_AU Occasional Contributor II 0 0 | 0 | 0 | |
Open | ArcGIS Pro 3.3.0As far as I can tell, the Item Description metadata style is the default style in ArcGIS Pro. That st... by Bud Notable Contributor 1 4 | 1 | 4 | |
Open | Pro uses a non-standard sorting method for file/folder names.Please fix this so it behaves the same as other applicat... by RTPL_AU Occasional Contributor II 5 1 | 5 | 1 | |
Open | ArcGIS Pro offers powerful symbology tools, but managing styles across multiple feature layers can be time-consuming.... by Dcrowley New Contributor II 0 0 | 0 | 0 | |
Open | Right now, I can go find an item on my computer or on one of the local servers (i.e. not AGOL), and add it to my proj... by MErikReedAugusta Occasional Contributor III 2 1 | 2 | 1 | |
Open | When you right click on a feature name in the Contents Pane and select View Metadata you generally are not seeing the... by SteveKovach New Contributor III 1 0 | 1 | 0 | |
Under Consideration | ArcGIS Pro 3.2.2 and 3.3.0In the browse dialog, if I click the lowest visible file/folder, then the dialog automatica... by Bud Notable Contributor 4 3 | 4 | 3 | |
Open | When starting a New Project in ArcPRO 3.2 the user can no longer type in the Location field. You have to click on th... by NoahWasserman New Contributor III 1 0 | 1 | 0 | |
Open | ArcGIS Pro 3.2.2:When dragging a layer in the Contents Pane:I'm able to scroll up or down by moving/dragging the mous... by Bud Notable Contributor 0 0 | 0 | 0 | |
Open | ArcGIS Pro 3.2.2:I have multiple maps in a project. I want to open a map by dragging it to the "view" tab section.Vid... by Bud Notable Contributor 1 0 | 1 | 0 | |
Already Offered | Quickly view a feature layer by right-clicking on it within the Contents pane and choosing "Display layer (by itself)... by Starc_Industries New Contributor III 1 4 | 1 | 4 | |
Already Offered | It would be helpful if user can add Excel Sheet (xlsx) data into map not only by Add Data but also with drag into map... by TomasPokorny New Contributor III 2 3 | 2 | 3 | |
Open | ArcGIS Pro 3.2.2@MErikReedAugusta put it well in Add multiple feature classes to Map as Group:Pro can sometimes be fi... by Bud Notable Contributor 1 1 | 1 | 1 | |
Implemented | For years I've had a working directory containing many Pro projects with the home folder being set to the working sub... by KarenAnderson New Contributor II 21 8 | 21 | 8 | |
Open | ArcGIS Pro 3.2.1[edited]With a .LYRX file, I can drag the file from File Explorer into [the map or Contents pane] wit... by Bud Notable Contributor 0 8 | 0 | 8 |
Idea Submission Guidelines
User | Count |
42 | |
15 | |
10 | |
9 | |
9 |
