ArcGIS Pro Questions
452
143.8M
18.2K
NOTE: ArcGIS Pro ideas require a single label. See the descriptions to choose the label that best aligns with your idea submission.
Open | There is a simple idea that is currently lacking across most LAS and point cloud editing software, in both GIS and 3D... by py4wildlife New Contributor III 2 0 | 2 | 0 | |
Closed | please export map from ArcGIS Pro to ArcMap,.mpkx convert to .mpk by qjyang New Contributor II 0 1 | 0 | 1 | |
Open | Currently, ArcGIS Pro provides three types of layer elevation settings for extruding 2D feature layers; absoulte heig... by KyleSeok New Contributor III 0 3 | 0 | 3 | |
Open | Nowadays, rendering 3D buildings via a LiDAR point cloud is doable in ArcGIS Pro 3 but, the direct 3D rendering is ve... by Ed_ MVP Regular Contributor 0 0 | 0 | 0 | |
Open | Currently, the only 3D model transfer format that ArcGIS Pro supports in terms of exporting is Collada. However Coll... by EricEagle Occasional Contributor III 1 14 | 1 | 14 | |
Open | I have many thousands of multipatches, closed and open, that need to be 'merged' based on an attribute. The only way ... by SamanthaGoodchild-Brown New Contributor III 1 1 | 1 | 1 | |
Closed | Better lighting options for 3D scenes. Add more flexibility how materials react to lighting. by BrianE1 Occasional Contributor 2 2 | 2 | 2 | |
Needs Clarification | It would be nice to be able to download assets via the Attachment Manager. In certain cases (scanned borehole managem... by ÁkosHalmai1 New Contributor 0 2 | 0 | 2 | |
Already Offered | ArcGIS Pro has the "move to" tool but this requires all 3 values to be populated (XYZ). It would be beneficial if yo... by DamienPyne Occasional Contributor 0 5 | 0 | 5 | |
Open | When a user creates a feature class (line or polygon), shape fields are automatically generated. When editing, those ... by BarbaraS Occasional Contributor 2 0 | 2 | 0 | |
Open | Just like the title says. I'd like to be able to export an elevation raster to any common mesh format (e.g., OBJ, ST... by EricEagle Occasional Contributor III 5 5 | 5 | 5 | |
Implemented | It would be great to import .fbx animated 3D models from other softwares like Maya, 3Ds Max .. or Blender and can be ... by JawadhHabeeb Esri Contributor 0 3 | 0 | 3 | |
Open | I would like to be able to select the multipatch objekts and chose if I want a .dae file for each objekt or to group ... by maricabancila New Contributor II 3 1 | 3 | 1 | |
Open | The field of 3-dimensional data is growing more and more but ArcGIS can not cope with standard formats like citygml w... by MartinRick Occasional Contributor II 12 3 | 12 | 3 |
Idea Submission Guidelines
User | Count |
42 | |
15 | |
10 | |
9 | |
9 |
