ArcGIS Pro Questions
452
143.8M
18.2K
NOTE: ArcGIS Pro ideas require a single label. See the descriptions to choose the label that best aligns with your idea submission.
Open | We are trying to import some BIM (Revit and IFC) data into ArcGIS Pro 3.1.4. The files are loading successfully, how... by Jeff_VanEtten Occasional Contributor 4 2 | 4 | 2 | |
Under Consideration | Working with Detail Plans and Zoning regulation often include to export GIS data to CAD format to consultants/entrepr... by MikaelGöthammer New Contributor II 1 3 | 1 | 3 | |
Implemented | Right now if you add CAD data to Pro it defaults to making a separate layer for each layer in CAD. If the source CAD... by KeithAddison1 Occasional Contributor III 2 2 | 2 | 2 | |
Open | In ArcGIS Pro 3.0, this ability was removed. See the documentation:https://pro.arcgis.com/en/pro-app/2.9/help/data/ca... by AdrianWelsh MVP Honored Contributor 6 1 | 6 | 1 | |
Open | Hi all,I have to quickly check area (square feet) of polygons in data coming from a CAD. dwg. It would be very nice t... by Anonymous User Not applicable 1 1 | 1 | 1 | |
Implemented | Hello all,I'm using ArcGIS Pro 3.1.0.When adding a CAD .dwg to Pro the CAD annotation color and location don't match ... by Anonymous User Not applicable 8 5 | 8 | 5 | |
Open | Hello,ArcGIS Map was able to import Civil 3D profile and section view from CAD drawings or basically most features fr... by JackLau New Contributor III 0 2 | 0 | 2 | |
Open | I was following along with the instructions at How To: Convert AutoCAD DWG files to a GIS-compatible file geodatabase... by wayfaringrob Frequent Contributor 3 3 | 3 | 3 | |
Open | Hello,Pro contains a powerful BIM/Building layer features filter, but for some tasks is quite cumbersome, moreover in... by TerezaHolubcova New Contributor II 4 0 | 4 | 0 | |
Open | We are finding that our ArcGIS PRO users are not able to solely rely on the Add BIM connection to work out which BIM/... by NickMiller2 Occasional Contributor 0 0 | 0 | 0 | |
Open | The integration of Revit files in ArcGIS Pro via the BIM cloud connection is getting better and better but this is on... by Stefan_Thorn Occasional Contributor II 2 0 | 2 | 0 | |
Open | I need to export 3D data to IFC. For example I created 3D buildings from drone imagery and now I'd like to give this ... by OleSeidel1 New Contributor III 1 6 | 1 | 6 | |
Under Consideration | Transformation Tab in ArcGIS ProDesktop has a Transformations Tab to key in the transformation data in a cad file and... by StevenLowman New Contributor II 2 10 | 2 | 10 | |
Closed | In ArcMap, you used to be able to open a CAD file in a Read Only mode. An if you wanted to create a shapefile you had... by MiguelMartinezYordan Occasional Contributor 4 2 | 4 | 2 | |
Implemented | It is very time consuming and uncomfortable to maintain the structure in the content pane when adding a CAD file. A C... by MiguelMartinezYordan Occasional Contributor 14 5 | 14 | 5 |
Idea Submission Guidelines
User | Count |
42 | |
15 | |
10 | |
9 | |
9 |
