Roberts Custom WAB Widgets
334929
475
12-31-2014 11:28 AM
RobertScheitlin__GISP
naveenb
hi robert,
could u plz work out on elevation profile widget.....as iam tied up with trying to developed dat.....
Naveen,
   I will consider this.
naveenb
Thanks for ur reply rob  and one more thing I want to ask is lyk while I'm passing the elevation service in to Geo processing tool I'm getting the ui part and I have drawn a line on the map I'm getting only x and y co ordinates on map evt geometry but we should get x,y and z to get the output that I have seen in an example. Could u plz help me whether we have to change the basemap to get that r any thing required for DAT.....ur response regarding will be helpful for my development.....
Regards,
Naveen.
Naveen,
   I have no experience with working with an elevation service like you are attempting so currently I can not be of any help.
DavidDas__GISP
Hi Robert,
Your Identify Widget will be a great addition.
Your Flex implementation of your enhanced Identify Widget was the ideal solution for us.
I liked how you could make a setting to Identify All Layers, and then you could drop a point on the map, and drill down to get the attributes of all the underlying layers, and copy the results to a text file.
You also had a way to select a specific layer from a drop down list and return a custom set of attributes.
Identifying features by drawing a shape (point, line, circle, rectangle, polygon, etc.,) was a great feature.
I would be delighted if you could bring some of this Flex functionality into your JavaScript version of the Identify Widget.
Thanks a million for making the Google Street View Widget!!
At this point ESRI should just get you onboard as their official Widget Wizard.
Best regards,
Tapas
Tapas,
   Did you ever work out your proxy issue?
DavidDas__GISP
Hi Robert,
I am still working on resolving the Proxy issues.
I found a thread that may have some clues. It explains how to make the Web AppBuilder work behind a corporate HTTP proxy:
https://community.esri.com/thread/105595
Best regards,
Tapas
AdamChavez
I was able to use that thread to fix my proxy, First I contacted the network guys and found our proxy address
:http://PROXYHERE:PORTHERE
Also be sure to right click the BAT file and "RUN AS ADMINISTRATOR"
BarnabyRockwell
Robert:  "Whats coming next?  I plan to begin work on an Identify widget."
Yahoo!
