Closest Facility Widget for Web AppBuilder
7122
8
01-12-2016 10:50 AM
Here's a port of my FlexViewer Closest Facility Widget for the Web AppBuilder.
http://www.arcgis.com/home/item.html?id=9a81bb2f4d7c416d8eaca4fe2864c910
Try it live here or get the code here.
Changes:
v1.1.5, 1/21/2016:
  • Fixed a problem in which some facilities datasets with lots of attributes confuse the solver. Create a copy of the facilities, but without attributes, before sending to the solver.
v1.1.1, 1/15/2016:
     * Settings page: animation duration field now forces the value to be a nonnegative integer
     * Displays a busy indicator while the server runs the solver
Comments
RickeyFight
MVP Regular Contributor
This looks awesome thank you!
RebeccaStrauch__GISP
CarmellaBurdi1
This is really amazing!
TimWitt2
This is great, well done!
GregNewton
Occasional Explorer
This is really cool.  I tried deploying on WAB 2.1, but it doesn't seem to be working.  Have you had any luck deploying on newer versions?
MarkDeaton
Esri Alum
Greg,
Sorry for the very, very late reply. I was able to use the widget fine in WAB 2.2. Did you make sure to copy the widget "ClosestFacility" folder into WAB's stemapp > widgets directory before creating a new application?
WAB CF widget in action
GregNewton
Occasional Explorer
Ok I did get it working.  After extracting, I renamed the folder "ClosestFacility." It was previously called closest-facility-wab-js-master.
MarkDeaton
Esri Alum
Thanks, Greg. I've updated the GitHub readme to include this renaming step.
Version history
Last update:
‎01-12-2016 10:50 AM
Updated by:
Contributors
