Hi Brett,If you run the code in the Python window it will work. If you use a standalone script, it won't :(. To solve this you should make a Featurelayer of TableView and describe those objects instead:Feature classimport arcpy fc = r'\\nlbltfs01\Projecten\307103\werkdir\fgb\BLS_Copy_Paste.gdb\Leiding' arcpy.MakeFeatureLayer_management(fc,"myLayer") desc = arcpy.Describe("myLayer") print "myLayer: {0}".format(desc.relationshipClassNames)
Results in:myLayer: [u'ZZRC_Leiding_Afsluiter', u'ZZRC_Leiding_Cap', u'ZZRC_Leiding_Diameterovergang', u'ZZRC_Leiding_Flens', u'ZZRC_Leiding_Isolatiekoppeling', u'ZZRC_Leiding_Las', u'ZZRC_Leiding_Leidingzakbaken', u'ZZRC_Leiding_Wanddikteovergang', u'ZZRC_Leiding_TStuk', u'ZZRC_Leiding_Pigmarker', u'ZZRC_Leiding_Ontluchting', u'ZZRC_Leiding_Mangat', u'ZZRC_Persoon_Leiding']Tabletbl = r'\\nlbltfs01\Projecten\307103\werkdir\fgb\BLS_Copy_Paste.gdb\Persoon' arcpy.MakeTableView_management(tbl,"myTable") desc = arcpy.Describe("myTable") print "myTable: {0}".format(desc.relationshipClassNames)
Results in:myTable: [u'ZZRC_Persoon_Leiding', u'ZZRC_Eigenaar_Duiker', u'ZZRC_Eigenaar_KruisendeWeg', u'ZZRC_Inspectieweg_Eigenaar', u'ZZRC_Inspectieweg_Onderhoud', u'ZZRC_KruisendeKabel_Persoon', u'ZZRC_KruisendeLeiding_Persoon', u'ZZRC_Onderhoud_Duiker', u'ZZRC_Onderhoud_KruisendeWeg', u'ZZRC_Persoon_Damwandkoker', u'ZZRC_Persoon_Gebouwen', u'ZZRC_Persoon_Gelijkrichter', u'ZZRC_Persoon_Handhole', u'ZZRC_Persoon_KruisendeMantelbuis', u'ZZRC_Persoon_Pachtkavel', u'ZZRC_Persoon_Peilbuis', u'ZZRC_Persoon_Wbe', u'ZZRC_Persoon_Grondzakbaken', u'ZZRC_Persoon_Leidingzakbaken', u'ZZRC_ZakelijkRecht_Persoon']Kind regards,Xander
