Hello, I am getting a different error when I run it in the Python Window in ArcGIS Pro:
### End setting variables
# Local paths to create temporary content
relPath = sys.path[0]
sddraft = os.path.join(relPath, "CitizenConcerns_all.sddraft")
sd = os.path.join(relPath, "CitizenConcerns_all.sd")
# Create a new SDDraft and stage to SD
print("Creating SD file")
prj = arcpy.mp.ArcGISProject(prjPath)
mp = prj.listMaps()[0]
arcpy.mp.CreateWebLayerSDDraft(mp, sddraft, sd_fs_name, 'MY_HOSTED_SERVICES', 'FEATURE_ACCESS','', True, True)
arcpy.StageService_server(sddraft, sd)
print("Connecting to {}".format(portal))
gis = GIS(portal, user, password)
# Find the SD, update it, publish /w overwrite and set sharing and metadata
print("Search for original SD on portal…")
sdItem = gis.content.search("{} AND owner:{}".format(sd_fs_name, user), item_type="Service Definition")[0]
print("Found SD: {}, ID: {} n Uploading and overwriting…".format(sdItem.title, sdItem.id))
sdItem.update(data=sd)
print("Overwriting existing feature service…")
fs = sdItem.publish(overwrite=True)
if shrOrg or shrEveryone or shrGroups:
print("Setting sharing options…")
fs.share(org=shrOrg, everyone=shrEveryone, groups=shrGroups)
print("Finished updating: {} – ID: {}".format(fs.title, fs.id))
Creating SD file
File "<string>", line 33, in <module>
File "c:\program files\arcgis pro\Resources\arcpy\arcpy\mp.py", line 105, in CreateWebLayerSDDraft
return _convertArcObjectToPythonObject(arcgisscripting._mapping.CreateWebLayerSDDraft(*_gp_fixargs([map_or_layers, out_sddraft, service_name, server_type, service_type, folder_name, overwrite_existing_service, copy_data_to_server, enable_editing, allow_exporting, enable_sync, summary, tags, description, credits, use_limitations], True)))
RuntimeError
