Oriented Imagery Catalog publishing fails
166
a month ago
tikola
by Esri Contributor
I have a Oriented Imagery Catalog that works well in desktop (latest 3.2 ArcGIS Pro and latest addon for Oriented Images). I try to publish that to AGOL (ArcGIS Pro - share as web layer) and that fails. It tells me about unsupported items and offers to select them for further steps - that does nothing:
So error I got is this:
00405: Oriented imagery dataset references unsupported items—ArcGIS Pro | Documentation
And what it does as a help does nothing - so nothing in my project never get selected. I have a feeling what those files are and I clean them away manually but in my perspective there is clear bug in this tool.
RandallRebello
Occasional Contributor II
I would like to apologize that you are experiencing this. Yes the messaging is not clear but we are working to improve the functionality and messaging of this feature.
From what I gathered from the team is that you are seeing this message because at the time of publishing the path to the images in the Oriented Imagery dataset has to be a http path. At the moment no other path is supported, ie if your images are pointing to a local drive you will see this error.
Hope this helps you.
Randall
tikola
by Esri Contributor
Actually as you now say it like this I remember this. I have seen this issue once before and solved that by uploading couple of files to AGOL. Now I have few files more so maybe it is Amazon etc. that will do the trick. Thanks for reminding me this issue - I should have known this - my bad.
But I agree that error message makes no sense😀
