I passed the same distance as a parameter into two different methods of the same Point Geometry, Buffer() and pointFromAngleAndDistance(), but the results shows different distance.
a. Point Geometry / b. point from the method pointFromAngleAndDistance() / c. buffered polygon from Buffer()
1. distance from pointFromAngleAndDistance() / 2. distance(radius) from Buffer()
The spatial reference of Point Geometry is EPSG 4326. (The point geometry objects for two methods is the same so, those methods are assumed to use the same distance measurement units of the same geometry's spatial reference.)
I also add a line of code to make the process.
My question is how to match two distances(1,2 in the image above).
Thanks for any help.
