ArcGIS Runtime Local Server Transformation Details
3785
11-25-2014 04:49 AM
SachinKanaujia
I need to get some information related to the CRS conversions. What is the default transformation with is being used by the ArcGIS Runtime local server when calling export image on Dynamic map service.
For example,
http://127.0.0.1:50000/arcgis/rest/services/empty0.mpk/MapServer/export?f=image&bbox=796964.901891,9...{"wkid":32056}&size=437,749&dpi=96&format=png32&transparent=true&imageSR={"wkid":32056}
The Shapefile data added is in WGS84 and the image is requested in wkid = 32056. What is the default transformation that is being used?
I need a complete list of transformations that will be used for CRS conversion by local server. If I dont know that then it will be difficult for me to exactly match with the projection that we are doing using Python script. Both should ideally be using the same transformation.
Eric BaderVijay GandhiMark Baird
